Latest post 08-21-2009 11:01 AM by Large48. 3 replies.
Page 1 of 1 (4 items)
  • 08-21-2009 10:14 AM
    Another Compatibility Q - Beosound 1 AUX and a CMM10
    Ok,
    Trying to sort out my CmM 10 - 10 Disk B&O CD Changer.
    I've been trying to get it to work with a Beosound 1 using the AUX port. Not a lot seems to happen :-( the CMM states that it acts like the TAPE2.
    I've since connected it to a BC9000 on using the TAPE2 socket and it all seems to be fine. ;-)
    So, can the Beosound 1 AUX socket act as a TAPE2 socket?
    Yours befuddled.........
    Train Hard - Run Fast - Hit to Kill!!!
    Filed under:
  • 08-21-2009 10:24 AM In reply to
    • madskp
    • Top 500 Contributor
    • Joined on 11-06-2007
    • Denmark
    • Posts 111
    • Gold Member
    Re: Another Compatibility Q - Beosound 1 AUX and a CMM10
    I don't think the Beosound 1 has datalink and therefore it will not have the ability to control the cd changer.
  • 08-21-2009 10:55 AM In reply to
    Correct, but the A.Aux of a BS9000 doesn't have datalink either
  • 08-21-2009 11:01 AM In reply to
    It works using the TAPE2 socket on my BC9000.
    So it looks like it won't ever work on the BS1?
