zjacs:
Jeff - Thanks but nothing is EVER easy for me! I guess it is just my luck.
I do not have the A Aux as an option in the Connection menu nor as a Socket. Also the List button does not seem to do anything.
What am I missing here? This cannot be this dificult.
Thanks Again.
Chris
Hold, you don't want AAUX! you want VAUX!
1.) You hooked up the cable from VGA->AV on the Avant
2.) You have named that port "VAUX"
3.) Follow the instructions on that LINK I provided, BUT SUB "VAUX" instead of the "AAUX" in that LINK.
...If you successfully added the "VAUX" to the "LIST" on the Beo4, you should be good!
4.) Beo4 should read "TV" at the top, with the set on.
5.) Press "LIST" repeatedly on the Beo4 when in "TV" mode until it displays the newly added "VAUX"
6.) Press "GO"
...All assuming you have "VAUX" able to be added to the Beo4. Otherwise, a bad cable or as in my initial post, the laptop isn't pushing the video.
OR! Might your Avant not be able to handle VGA input??? <searching and will post later>
I am not home, so I can't go much further, hopefully someone else may come along!
P.S. Welcome to BeoWorld... this will be sorted!
