Hi
I have connected a projector to my Beovision 7 with a DVI cable and in the BV7 menu specified a projector on display 2 but how do I get Beovision 7 to direct the signal to the projector and not the LCD display???
Regards
Lars
OK, got it. Format 0. A search did the trick Thanks.
3 minutes to find the cinema function on Beo4 - that is quick! - Tillykke
Stefan
just a little tip
make sure you format 0 back to the LCD panel b4 u turn of the projector as it can cause issue and not return to the display if you turn of projecor then try to return to the LCD display
Beovision 7 MKIV (Blu Ray)Beolab 9Beolab 6000Beo 4Beocenter 9300Apple TVSKY HDOptoma HD65 ProjectorLintronic TT455-RT-238Beovision 3 MKII
stefan: 3 minutes to find the cinema function on Beo4 - that is quick! - Tillykke Stefan
Tak Next time I'll do search first and THEN do a post
Seanie: just a little tip make sure you format 0 back to the LCD panel b4 u turn of the projector as it can cause issue and not return to the display if you turn of projecor then try to return to the LCD display Thanks
Thanks. I did. Wonder if the kids will remember??!!
Connect a Lintronic box to the cinema control module of your BV7 , program a macro and let the Lintronic box do the cinema function....
