Welcome to BeoWorld! Glad to have you here.
I assume that what you have is a BeoVision 7 with one of the BeoLab 7-x's on one of the motorized stands. There is no 'lock' function for those stands, so you do have a problem. There is one general item you can check easily, go into the options menu and see if the 'stand' option is available; if not, the likely issue is that the cable connecting the TV to the stand has come loose from the TV. Unplug the Mains power, and re-attach the cable. Power the TV back on and try it again. This can be an issue with all 3 of the motorized stands.
If 'Stand' does appear in the menu, but it won't move, then there is a different issue. Here in the US, we have had an issue with the motorized floor and table stands for the BV-7 40". They no longer come from the factory assembled, and when done in the field, they have been known to lock or freeze up after working fine for a while. The solution is to loosen the screw on the bottom of the stand which holds the riser-posts in place, and gently but firmly make certain that it is fully seated all the way down then begin to re-tighten that screw while continuing to work the posts down. I do not know if the stands for the 32" have the same problem. It is, of course,suggested that you remove the TV from the stand while doing this as it involves a fair amount of wiggling, shaking, and perhaps cursing.
Russ
We kid because we love.
Bang & Olufsen Tysons Galleria
McLean, VA USA
