1st March February 2012
08-06-2009 1:40 PM
richtoy
- Joined on 09-20-2007
- Valkenburg, Netherlands
- Posts 184
Will upgrading to the latest STB-C eeprom (4.01 ??) which contains several Humax entries give me any support for a Humax or any other Freesat box??
Regards
Richard
Some of my B&O: BV3/32, MX7000, MX5500, LX5500, MX4000, BM8000, BM6000, Overture, BL8000, BM6000 Quad, BM4400, BM3400, BG-CDX, BM3000, BM1001, BM1200, BM1600, BM1700, BM1500, BM1400, BM2400, BM2300, BM4500, BM4000, BVM70, BVS45-2, BVS60, BC7700, BM2200, BM1900, BG8002, BM1202, BVPenta, BVP45
Keith Saunders
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
Richard,
The latest STB-C western European version is 4.11
Version 4.01 supports the following Humax products:-
HUMAX Cl-51 OOC HUMAX CI8100PVR HUMAX DTI-41 00 HUMAX F1-VACI HUMAX HDCI-2000 Humax IPVR 9200C HUMAX PR-HD1000 HUMAX PVR 9200T
Version 4.11 supports the following Humax products:-
HUMAX Cl-51 OOC Humax IRHD-5000C Humax IR-FOX C Humax IPVR 9200C HUMAX PVR 9200T HUMAX HDCI-2000
As all Humax use NEC protocol and assuming they all also use the same product address code which would need to be established then most of the common functions are likely to work.
meandmyshadow
- Joined on 04-17-2007
- Posts 339
Keith Saunders:
Richard,
Keith,
4.11 also has HUMAX FOX SAT HDR on the list, I know because i've just installed it on my BV5 . the part number is 8344785.
Page 1 of 1 (7 items)
