Latest post 08-11-2009 4:56 AM by TWG. 8 replies.
Page 1 of 1 (9 items)
  • 08-05-2009 1:43 AM
    Can't access copied CDs on BeoSound 5
    Hello,
    a few months ago I had my new BeoSound 5 installed and all worked well, also the connection with the Comupter (PC, with Windows Vista). For a while now I have the problem that I can copy new CDs on the BeoMaster (via BeoPlayer), but I cannot access them on BeoSound and in BeoPlayer they only show up under "Folders" and not under "Artists" or "Albums". After copying the CDs with BeoPlayer I can see the CD on BeoMaster (network drive), but somehow I cannot access them with the BeoPlayer or via the BeoSound 5 machine.
    Anybody come across this problem?
    Any advise would be highly appreciated.
    Gerald
    Filed under: ,
  • 08-05-2009 10:15 AM In reply to
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    Re: Can't access copied CDs on BeoSound 5
    Hello Gerald,
    perhaps a stupid question but did  you try to reboot the Beosound 5?
    And do you see the recently copied CDs on the Beosound 5 (NOT the network drive, directly when using the wheels on the BS 5)?
    Do you have another Computer with e.g. Windows XP or Mac OS X installed to test if it's the computer?
  • 08-05-2009 1:31 PM In reply to
    I did reboot (more than once), which did not change the issue and I also tried it from another computer (with XP). And I cannot see recently copied CDs on the BeoSound 5 - I can only see it on the network drive.
  • 08-06-2009 11:12 AM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    Did the files go into the wrong folder on the Beomaster? Could that possible? Do you see in which folder on the network drive your music is stored?
  • 08-06-2009 11:43 AM In reply to
    The new files are in the "Music" folder - just like the CDs I transferred a few weeks ago - no differences to be detected.
  • 08-06-2009 3:22 PM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    Do you have an USB mouse?
    If yes: Plug it into the Beomaster USB Port. Enter service menu (on the Beosound 5 controller press: < < > > Go) and select service mode or service desktop (I'm in the office actually, I don't know the correct name ;-)).
    After this you'll enter Windows Desktop (that's why you'll need the mouse). Please have a look inside your music folder on the drive named "Data" -> \Bmshare\music.
    Is your recently copied music inside that folder? And is it realy(!) the music file or a ghost file from indexing the harddrive on your host computer which has another file extension!?
  • 08-06-2009 6:56 PM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    TWG:
    It's as simple and intuitive as that!
  • 08-11-2009 3:08 AM In reply to
    Thanks for those hints, but this does not solve the problem. All the files and folders are in the right place on the Windows Desktop that I have accesed via the BeoSound 5. And there are not ghost files, they are all there with all their bits and bytes.
    Any more ideas?
    Gerald
  • 08-11-2009 4:56 AM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    Perhaps there's s.th. wrong with the file attributes?
    Right click on one of the unaccessible files: Are they marked with "System", "Locked" or s.th. like that?
