Latest post 08-03-2009 12:51 PM by Keith Saunders. 2 replies.
Page 1 of 1 (3 items)
  • 08-03-2009 10:35 AM
    Beo 5 IR to RF converter
    I have a problem because the Beo 5 only transmit IR-signals.
    I was hoping that someone knows about some kind of converter box, that receives IR-signals  and convert them to a specific RF-signal frequency?
    Examples of typical RF-products that would be nice to control with the Beo 5:
    -Velux windows with io-homecontrol  RF-remote.
    -Awning/overhang always uses RF-remote control.
    Filed under:
  • 08-03-2009 12:31 PM In reply to
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    Re: Beo 5 IR to RF converter
    those transmitters are available from:
    - Logitech (Harmony remotes)
    - Philips (Pronto remotes)
    But I don't think/know that/if they're compatible. Perhaps you can buy one of those boxes plus the Lintronic Ir converter.
  • 08-03-2009 12:51 PM In reply to
    The problem currently with consumer RF remotes is the lack of any standards.
    In fact the leading consumer electronics companies like Panasonic, Philips, Samsung and Sony have realised the problem. Working together, they have launched the RF4CE Alliance that is establishing a worldwide standard for RF-remote controls. The frequency band selected for this is 2.4 GHz - available worldwide (known from Bluetooth and Wi-Fi) and the protocol is based on the IEEE 802.15.4 standard that exists since 2003.
    In March 2009 a press release was made announcing the alliance which you can download HERE
    Some companies have produced converters for particular products as already stated, but almost all the existing RF controllers use a different protocol, and that is why you will not find a general IR to RF converter for sale.
    Frankly, at present the only way to have an IR to RF converter for a particular product would be to build one yourself or have it built for you, or if you are very lucky and a converter has been produced for the product you are interested in..
    Regards Keith....
