Afternoon all
I've just picked up a whole Beosystem 6000 and have a few questions. I've scoured the forums for answers before posting but a few questions remain unanswered, so I'd really appreciate some wise words (as I'm a novice to all of this) – sorry for posting all at once – someone please tell me if I’d be better off breaking this up!
1. The BM6000 seems to be working perfectly - all LEDs operational, even heat on the heatsink, volume controls all working. The system came with some S120s that need refoaming so in the meantime I was thinking of using some 3800s that I've got. However I note there is no 4ohm rating listed for the BM6000, just 75W into 8ohm. I don't want to damage either amp or speakers by matching inappropriately so providing I'm not driving these hard, will they be OK temporarily? I've got some refoamed S80s so would they be preferable?
2. I noted on the BM6000 page on here that an Active AM Antenna AA 10 was listed as an accessory, which confused me a little as I thought they were FM only. Not really knowing what the antenna was and being a big fan of Radio Five Live, I wondered if it was perhaps a clever self contained AM receiver that could be plugged in via a spare input. I found one of these for sale recently and bought it unseen before picking up the 6000. On receiving the antenna, it's obviously just a powered AM aerial - can someone just confirm that it's not for use with the BM6000 after all?
3. The BM6000 was advertised as having a remote control but when I got it, the remote was the Beolink 1000 which seemed an unlikely match. It didn’t work but I haven’t yet tried it with fresh batteries. I have seen something on here about potentially using a Beolink 1000 with a BM6000 if you had an IR code converter kit and a modification was made to the amplifier. I’ll try the remote with some new batteries and let you know. Anyone know anything about this? There are a couple of potentially encouraging signs – the cover for the IR sensor on the BM6000 has been removed at some point but then pushed back on slightly wrongly so thus far I haven’t been able to check to see if there is the optional remote control board present. Also in the bag of cables etc that I got, there is something which looks a lot like this IR receiver which I guess could have been part of the code converter process???? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=250464116365
4. Apart from having to reset the clock, is there any problem with turning the unit off at the mains between uses? I saw something somewhere about this not being advisable for one particular amp (don't know which one) due to the amount of “retained” power in the unit (sorry, layman’s language!). Is this rubbish???
Thanks in advance and sorry for the lengthy first post!!!
All the best
I
