Normal
0
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0in;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
p
{margin-right:0in;
mso-margin-top-alt:auto;
mso-margin-bottom-alt:auto;
margin-left:0in;
font-size:12.0pt;
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
Hello,
I'm a new member and this is my first post. I think the Beogram 3404
is a bit of an oddity, but I hope someone can help.
I recently acquired this record deck, which has had one owner since
1981. It is in good shape, but it has one major problem. The black
plastic piece (don't know if it has a name) that supports the tonearm
does not seem
to be functioning. The needle rests, unsupported, on the record deck;
it
does not lift or drop when "start" is pressed. If I manually place the
needle on a record, it will play, but at the end of the album it will
not lift up, but it drags/scratches accross the record back to its
starting point. I don't know if there
is something I can do to get this black piece to maintain and then drop
the
tonearm, or if it is actually broken and needs to go in for a repair.
If any can offer advice, it would be much appreciated.
Thanks,
Michael
