Latest post 07-09-2009 5:37 AM by beoaus. 4 replies.
Page 1 of 1 (5 items)
  • 07-08-2009 10:50 AM
    apple tv on avant 32 inch
    Does anyone know if the apple tv works with an B and O avant television?
  • 07-08-2009 7:27 PM In reply to
    Re: apple tv on avant 32 inch
    applemac1:
    Someone else probably knows better, but I think you'll be facing the same kinds of problem as me with BV5 and apple TV. The apple TV has HDMI and component. my BV5 has neither, and a simple component to scart adapter is not enough, but expensive "transformers" are needed. I skipped apple TV for a mac mini.
    To the Apple mini dvi there are adapters available from apple to make it into video. So I'm guessing this is a better solution. Apples front row software is great, much similar to apple TV.
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 07-09-2009 4:39 AM In reply to
    Yes I thought it would not work, thanks Andreas maybe the mac min move is the better idea. However I already have an apple imac thats why I wanted to go the tv route. I know how the front row works it is great. Whats it like on your BV5
  • 07-09-2009 5:28 AM In reply to
    • Thomas
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Norway
    • Posts 85
    I have an Avant 32 DVD with an apple TV connected through one of these : http://www.svideo.com/appletv2tv.html
    It works as a charm through the second STB-C controller in my TV (ATV have a learning possibility so I havent even updated the STB-C sw)
    I really recommend this setup.
    Br
    Thomas
    7-40 Mk3, Beo5/Beo4, Avant32DVD, BS3K, PentaIII, BL4K, BL Active w/BL2500, Avant28CTV,Beoport, AppleTV, 2xBC6K
  • 07-09-2009 5:37 AM In reply to
    • beoaus
    • Top 150 Contributor
    • Melbourne, Australia
    • Posts 445
    You can use this link.  http://www.appletvhacks.net/2007/10/12/get-color-output-from-apple-tvs-composite-video-output/
    Down the page they suggest using a HDMI to DVI or like adapter. You short out pins 14 ang 16 using a paperclip.  It works as instructed. Brilliant hack. If you restart the unit you do it again, simple.
