Latest post 06-30-2009 7:38 AM by onyx. 2 replies.
Page 1 of 1 (3 items)
  • 06-30-2009 4:16 AM
    • onyx
    • Not Ranked
    • Joined on 04-15-2009
    • Posts 8
    BS4500 and beolink pc2
    Hello guys,
    I have a BS4500 and two link rooms, one with BL3500 and the other with MCL2A, both with MCL cables.
    May I connect my PC in another room trough e.g. 'a beolink pc 2' and an 'ML/MCL' or another converter to listen
    PC music in link rooms?
    Thanks,
    onyx
  • 06-30-2009 5:38 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: BS4500 and beolink pc2
    Won`t work I`m afraid. BS4500 can not distribute N.MUSIC, N.RADIO. If you press N.RADIO  on your Beo4, it will activate the PHONO socket of your BM4500. You will need an audiomaster like BS4, BS3000, BS9000.
    But if you just want to listen to your PC output, without any control, just connect it to a vacant BM4500 input and select this one in your link room.
    Stefan
  • 06-30-2009 7:38 AM In reply to
    • onyx
    • Not Ranked
    • Posts 8
    hello and thanks Stefan,
    this is really a bad notice for me...
    Much more if I think that it shold be possible (trough the BS4500 aux/datalink port and a beolink converter),
    just a software upgrade should do the job...
    bye
