There is no proper beamer out available on the BV8-40, but you can still use a beamer. How to connect it depends on what sources you would like to view on your beamer. I also purchased the BV8-40 and have a beamer. I did not completely finish the setup yet, but this is how I will connect it:
- DVD/Blue-ray: HDMI to BV8, Component to Beamer
- Digital cable receiver: HDMI to BV8, Component to Beamer
This way you can watch both sources on your beamer and mute your picture. I had a similar setup with an avant and that worked fine. I use a lintronic to control the beamer.
Bieele
