Hello everyone! I recently picked up a BeoCenter 7002 for $65. I'm super excited to get this system up and going but I'm having some trouble with the phonograph portion.
Here is what happens:
I place a record on the turntable (the transport screws are in "play" mode)
I touch play and the arm moves over to the records surface
music begins to play but after 8 secords or so it begins to skip and it looks like the needle continues to move in, but the arm won't move. If I move the counter-weight in (towards the cartridge) the same scenario unfolds but as the needle gets pulled in the toward the center it doesn't skip right away but the sound begins to distort heavily. Just to clairfy when I say "the needle gets pulled toward the center" it appears as if the tone arm is staying still but just the needle on the cartridge begins to flex laterally toward the center of the record. I stop it before it bends to much so as not to cause damage.
Is there a mechanism that could be causing the tone-arm not to move with the record properly? Could improper counter-weight adjust cause this? Just looking for some help. I have no reason to think the MMC-20EN cartridge is bad. What are some easy ways to diagnose a bad cartridge? Any and all help is appreciated.
