Latest post 06-22-2009 3:04 AM by Dillen. 3 replies.
Page 1 of 1 (4 items)
  • 06-21-2009 12:22 PM
    BeoCenter 7700 static
    Suddenly my BeoCenter 7700 has static noise when playing either the radio or turntable.  When I hit the RESET button the noise disappears...for about two seconds, then it returns.  Anybody know what may be causing this?
    tlincoln
  • 06-21-2009 4:56 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: BeoCenter 7700 static
    Hello and welcome to Beoworld !  Yes -  thumbs up
    There are quite a few grounding leads inside, they are all black and running from board to board and various
    other (metal) things.
    Maybe one of them has broken off, I would start looking around the processor module.
    Could also be a ground connection in a plug, cracked solder joint(s) or similar.
    Finally, capacitors can never be ruled out, they can cause the strangest faults.
  • 06-21-2009 8:57 PM In reply to
    Martin,
    Thanks for your reply;  I didn't expect a response so quickly.  Now that you've identified some of the possible causes I
    have to tell you that I don't possess your technical knowledge.  So, another question:  Do you know where I can access
    some kind of illustration that identifies such as grounding leads, processor module, capacitors, etc?
    Thanks,
    Tlincoln
  • 06-22-2009 3:04 AM In reply to
    • Dillen
    • Posts 5,008
    The service manual will show you how the Beocenter is made. It's available for download from the our main site for
    silver and gold members.
    Obviously a job for a tech guy, I wouldn't recommend you open it yourself unless you are a trained technician.
