Latest post 06-01-2009 6:41 PM by Stonk. 1 replies.
Page 1 of 1 (2 items)
  • 06-01-2009 5:41 PM
    • Kirk
    • Not Ranked
    • Joined on 06-01-2009
    • Posts 1
    Beovision MX5000
    I need help operating without my 1000 remote which is not working.
    I can use the on/off and it seems the other buttons changes the channel up. but how can I turn th channel down?
    Also is ther any local volume contorl?
    Thank you.
    Kirk
  • 06-01-2009 6:41 PM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    Re: Beovision MX5000
    Hi Kirk,
    Unfortunately without a remote the MX5000 is useless. The buttons on the MX are very basic and only usable only after you have tuned it in with the remote.
    You say your Beolink 1000 is broken - what exactly is the problem? Is it dead? Have you tried changing the batteries? If so look at the remote through the camera on your mobile to see if the infa red lights up..
    Steve
    If you think nobody cares, try missing a couple of payments.
