Latest post 05-26-2009 5:24 AM by slupascu. 2 replies.
Page 1 of 1 (3 items)
  • 05-24-2009 4:46 PM
    Connecting a ML/MCL convertor to an Ouverture unit . Any difference between Masterlink and powerlink ?
    Hi there,
       I have to connect an Ouverture unit to a MLMCL converter and from the converter to passive speakers.
       Can I connect the ouverture to the ML/MCL  with powerlink also ? I don't need the benefits of masterlink since they are in the same room.
       Is there any bennefit to connect them via masterlink In a few words I want to use the ML/ MCL as a MCL2P connected through powerlink.
       I'm asking because I don't have a  masterlink  cable and need to know if I loose something in matter of sound  quality .
    Thx in advance to this great community
    Stefan
  • 05-25-2009 3:23 AM In reply to
    Re: Connecting a ML/MCL convertor to an Ouverture unit . Any difference between Masterlink and powerlink ?
    There is no benefit in using ML in your situation. Simply use a MK2 powerlink cable.
    Regards Graham
  • 05-26-2009 5:24 AM In reply to
    Thx a lot Graham.
    This is what I was planning to do.
    Regards,
    Stefan
