Latest post 05-21-2009 2:29 PM by Steve at Sounds Heavenly. 3 replies.
Page 1 of 1 (4 items)
  • 05-19-2009 9:03 AM
    iPod in Beocenter 2/Beosystem 2
    Hi, I've got a question about my Beocenter 2. It's connected to a Beosystem 2, and on this Beosystem are 2xBL8000, 2xBL2, 1xBL3500 and 1xBL2. Now I would like to connect an iPod to this system. Where can I connect it? The Beosystem seems to have only video connections... Please, help me out!
    Thanks a lot in advance!
    Nicolas (Belgium)
  • 05-19-2009 11:47 AM In reply to
    Re: iPod in Beocenter 2/Beosystem 2
    Can't you just use AUX in on the Beocenter 2?
  • 05-19-2009 1:39 PM In reply to
    If you do not wish to use a third party device for control of the IPOD, you can use the camcorder audio sockets - you may need to add CAMC to your BEO4.  These are the red and white phono sockets, yellow is for composite video so you do not need that - you may need a cable made up from Sounds Heavenly.........
  • 05-21-2009 2:29 PM In reply to
    Either option will work, I would go for the Aux inputs on the BeoCenter myself, for simplicity.  Let me know if you need a cable for either option! Big Smile
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
