Latest post 05-18-2009 8:36 AM by StUrrock. 2 replies.
Page 1 of 1 (3 items)
  • 05-17-2009 2:23 PM
    Beoworld Sony PS3 Nyko Full XML and Hard Keys
    Frustrating problem:
    Using the Beoworld Sony PS3 Nyko Full XML configuration in Beo5 2.20 Configuration Tool.
    In "Edit" tab I drag the the soft keys (i.e. "Forward4", "Left arrow4", "Rewind4" etc.) to the hard keys and checking the "properties" of each hard key confirms the "3partyIR" placement. Switch to "View" tab to test setup, push "PS3 Nyko" button in virtual screen (to engage PS3 Nyko mode) and many of the hard keys lose their configuration and either don't work or revert to original "BeoIR" setup.
    Is this a known issue, or am I (most likely) doing something wrong here?
    Thanks!
  • 05-17-2009 4:39 PM In reply to
    Re: Beoworld Sony PS3 Nyko Full XML and Hard Keys
    A Very warm welcome to Beoworld and your first posting.
    You may wish to download an updated XML file for the Sony PS3 Nyko which has the hard keys already assigned.
    You can download teh replacement XML file HERE
    Regards Keith....
  • 05-18-2009 8:36 AM In reply to
    • StUrrock
    • Top 500 Contributor
    • Joined on 02-04-2008
    • Cambridgeshire
    • Posts 219
    The file works brilliantly.
    Thanks Keith
