Latest post 05-15-2009 12:53 PM by Gerd. 1 replies.
Page 1 of 1 (2 items)
  • 05-15-2009 7:51 AM
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    Beo 5 Option programming
    I have some trouble with the  option programming of the Beo 5:
    Configuration in the livingroom:
    - Avant (stand alone)
    - BS 3000 (audio master)
    - BS 5 (no audio master, linked to BS 3000 via Masterlink)
    I set the options in the configuration tool as follows:
    - Avant: "2 receivers in the same main room"
    - BS 3000: "2 receivers in the same main room"
    BUT: When I transfer it to my Beo 5 and hit "option programming" for the living room the TV activate itself and the Bs 3000 doesn't react to the remote anymore!
    If I use the Beo 4 and set TV and BS 3000 to option 1 (Video Option 1 for the TV, Audio Option 1 for the BS 3000) everything works as it should.
    How can I solve this?
  • 05-15-2009 12:53 PM In reply to
    • Gerd
    • Top 150 Contributor
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    Re: Beo 5 Option programming
    Assuming you have speakers connected to the Beosound you have to create 2 zones!
    Check also the chapter "Create zones" in the help file.
