Latest post 05-14-2009 7:31 PM by jbaunsoe. 5 replies.
Page 1 of 1 (6 items)
  • 05-11-2009 12:57 PM
    Beomaster 4500 and Beogram 2000
    Please help me - I have an old BG2000 and I've just got a BM4500. I wonder if these two are compatible?
    /Jesper
  • 05-11-2009 1:12 PM In reply to
    Re: Beomaster 4500 and Beogram 2000
    You will need a RIAA pre amp between them as the BM4500 expects a 1volt signal from the deck.
    Regards Graham
  • 05-11-2009 1:45 PM In reply to
    Thank you, but...Any specific RIAA pre amp you can recommend? Sorry to ask - I'm a rookie in this subject :)
    /Jesper
  • 05-11-2009 2:08 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    The easiest solution would be to purchase a RIAA pre-amp kit from either Lee at LifestyleAV or Steve at Sounds Heavenly. Both sponsor beoworld and can be found by clicking on the links at the foot of the page for soundsheavenly or the head of the page for lifestyle.
    The beauty of buying a ready made kit is it will include ALL interconnecting leads which are of high quality from these sellers.
    Chris.
  • 05-11-2009 2:12 PM In reply to
    jbaunsoe:
    /Jesper
    They are available from £10 to thousands! Just what the difference is I don't know and probably can't hear anyway. I suggest you google or look at amazon and see what you fancy. There used to be one called the "Discsaver" but as far as I know it is no longer made.
    One of the Beoworld sponsors, Soundsheavenly, can supply a reasonable one complete with leads to suit. His advert is at the bottom of this page.
    Regards Graham
  • 05-14-2009 7:31 PM In reply to
    Useful stuff and info - great! Thanks for the help, it is more than good enough to get me startet ont this very little project :)
    /Jesper
