Latest post 05-03-2009 8:53 AM by Andy . 2 replies.
Page 1 of 1 (3 items)
  • 05-02-2009 5:34 PM
    • Andy
    • Top 500 Contributor
    • Joined on 07-24-2007
    • Melton Mowbray
    • Posts 128
    Beocord 8002 veneer templates
    Hi
    my Beocord 8002 needs new veneer as its looking very tattered. Are there any templates available so that I can cut to the correct siz and shape??
    Andy
  • 05-03-2009 2:46 AM In reply to
    • geearr
    • Top 200 Contributor
    • Joined on 03-27-2008
    • Gold Coast, Australia
    • Posts 301
    • Gold Member
    Re: Beocord 8002 veneer templates
    Hi Andy
    I am not sure why you should need a template for the side panels.  I have replaced a few veneered panels simply by removing the old veneer, cutting a new piece slightly oversize and sticking it on.  After the glue has set, the veneer can be carefully sanded (or “dremelled” in the more awkward places) to establish the correct profile around the plastic backing.  Always try out this process on a spare panel first -  if you have one.
    Good luck
    Geoff
  • 05-03-2009 8:53 AM In reply to
    • Andy
    • Melton Mowbray
    • Posts 128
    my side panels are completely broken in many places so would be difficult to use as templates. I will try as you describe
    Thanks again
