Latest post 05-05-2009 7:11 AM by Sandrikor. 14 replies.
Page 1 of 1 (15 items)
  • 04-28-2009 9:49 AM
    Western Digital TV- Pronto Hex Codes -Beo5
    Hello , i Just Bought The WD Tv and was trying out to Convert the hex codes of its remote to beo5 .... Somehow i seem to fail all the time ...Here are the Codes if someone could convert them to aN Xml File for the Beo5 Would be much Apreciated ...Thank you in Advance !
    Power 900A 0068 0000 0001 8479 12ED
    Home 900A 006D 0000 0001 8479 06F9
    Up 900A 006D 0000 0001 8479 05FA
    Down 900A 006D 0000 0001 8479 00FF
    Left 900A 006D 0000 0001 8479 07F8
    Right 900A 006D 0000 0001 8479 09F6
    Enter 900A 006D 0000 0001 8479 08F7
    Back 900A 006D 0000 0001 8479 1BE4
    Option 900A 0068 0000 0001 8479 1AE5
    Stop 900A 0068 0000 0001 8479 04FB
    Rev 900A 006D 0000 0001 8479 1FE0
    FF 900A 006D 0000 0001 8479 1EE1
    Play/Pause 900A 006D 0000 0001 8479 0AF5
    Prev 900A 006D 0000 0001 8479 02FD
    Next 900A 0068 0000 0001 8479 01FE
    Search 900A 0068 0000 0001 8479 0FF0
    Eject
    900A 006D 0000 0001 8479 10EF
    http://wdtv.wetpaint.com/page/Remote+Control+Issues?t=anon                                           And the link.....
  • 04-29-2009 4:52 AM In reply to
    Re: Western Digital TV- Pronto Hex Codes -Beo5
    Whilst the codes you have found are valid Pronto codes, most found on the web are "Learn't codes
    If you have a learn't code, then the first word of the code string will always be "0000" if the signal is modulated and "0100" if unmodulated
    If it is non zero, then it is a defined protocol or a proprietary defined by a vendor like Western Digital
    Defined protocols include:-
    0000 Learned code format (modulated)
    0100 Learned code format (unmodulated)
    5000 RC5 code format
    5001 RC5x code format
    6000 RC6 code format
    6001 RC5 mode A code format
    Code "900A" is new to me, so we can assume at this stage it is a Proprietary defined code, but can still be decoded, but will take a little longer.
    What seems surprising is it uses two different carrier frequencies which is unlikely, but not impossible.
    I will decode it cover the next couple of days and get back to you.
    Regards Keith....
  • 04-29-2009 5:04 AM In reply to
    Hmm interesting seems thats why i was having so many problems with those....  i assume more peps are using WD TV  so the decoding of those would be usefull for all ;) ill be waiting then for ur conclusion ^  thnx in advance keith ;)
  • 04-30-2009 4:40 PM In reply to
    I have put together a test XML file for you to test.
    You can download it from HERE
    Regards Keith....
  • 05-02-2009 10:28 AM In reply to
    A great Keith will test it right away  and let u know how it went !
  • 05-02-2009 11:07 AM In reply to
    Gave them a try seems like none of the buttons are actually working
  • 05-02-2009 11:20 AM In reply to
    Nope preety sure now after some tries that the buttons dont work
  • 05-03-2009 10:59 AM In reply to
    I am sorry it did not work, but I was guessing at the protocol used which clearly was incorrect.
    Do you have the opportunity to capture one command from the original remote and send me the timing, then I can be certain about the protocol used ?
    Regards Keith....
  • 05-03-2009 11:29 AM In reply to
    Hey Again keith , nope afterall didnt bought the lutron ir converter so i cant send you the timings ...  so i guess we are at a dead end .. hmm any other ideas that might help ?
  • 05-04-2009 4:04 AM In reply to
    If you have a Windows Mobile or PocketPC lying around you could get a low-cost solution for capturing IR codes within RemoteControl II software. Search for it in this forum, worked for me.
    Cheers,
    Frank
  • 05-04-2009 9:47 AM In reply to
    All we need to do is establish what protocol Western Digital are using as I am not familiar with the Pronto code you had found on its web site.
    As Frank said, you don't need a Lintronic box to capture an IR signal, there are many options and I only need one command capture to establish the protocol.
    Regards Keith....
  • 05-04-2009 10:14 AM In reply to
    I have done a little more research this afternoon and I can now confirm that this code uses NEC protocol which is what I had previously guessed and provided as a XML file.
    However, it is now much clearer that Western Digital may have translated the function and inverted function code incorrectly, This is HEX word 5 of the Pronto code.
    So, we now know that Western Digital has used a non standard leadin code of 900A to represent NEC.
    I will look at word 5 & 6 and see how they have defined them and gte back to you.
    Regards Keith....
  • 05-05-2009 4:58 AM In reply to
    I am pleased to inform you that I now have an XML file for the Western Digital TV for you to test, but I expect it to work.
    Those commands such as UP & Down etc are assigned to the hardkeys
    You can download the XML file for test HERE
    Regards Keith....
  • 05-05-2009 6:58 AM In reply to
    Hey Again keith and sorry for the slow reply ,  great to hear i will give it a try now to see if it works , and nope dont have either a pocket pc or other ways of capturing ir commands ..anyway let me see how this file will do ^^ will get back to u
  • 05-05-2009 7:11 AM In reply to
    And As u Said Keith The File Works Perfectly !!! Thnx A milion !!  For All the time and Effort u put into this ;) Cheers man :):):)
