Latest post 04-28-2009 3:22 PM by beo4me. 6 replies.
Page 1 of 1 (7 items)
  • 04-27-2009 2:59 PM
    BeoVision 3-32 only on 4:3
    Hi there, I have a client that owns a Beovision 3-32. After we plug in a set-up-box for cable TV the BeoVision change is format to 4:3 and wont come back to 16:9, even on RF input. Can u please help? BEOVISION 3-32 TYPE NÂș 8800 SW 8.80 Thanks in advance.
  • 04-27-2009 3:16 PM In reply to
    Re: BeoVision 3-32 only on 4:3
    Hi Sprozio
    You have to enter the menu on your set-up box and change format there
    regards
    jan
  • 04-27-2009 3:30 PM In reply to
    birgerbum:
    Hi Sprozio
    regards
    jan
    Thanks for the fast reply.
    Now, even with the set-up box unpluged, the image is always in 4:3, even in the coaxial (RF) input .
    Any other ideas?
  • 04-27-2009 3:52 PM In reply to
    It's more than likely the format 1 setting, switch the TV on (terrestrial at this stage) and choose a channel that you know is broadcast in 16:9 then press list on the Beo4 repeat until FORMAT appears in the display then press 1.  When you have done that press th >> button and see if you can get it back to it's correct format, if I'm remembering correctly they're 3 options in that mode just choose the correct one.
  • 04-27-2009 11:34 PM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    pressing >> for format might not do anything, if not, you can simply press 3 (after selecting format of course). I've had this issue as well with my set top box. You M U S T ensure your set top box settigs are correct. The BV3 ratio is always going to be automatic and even if you do change the format automatically it will revert back to format 1 until it gets the right signal for the format 3.
  • 04-28-2009 2:59 AM In reply to
    Thanks for the replys guys!
    I´m going there this week, I'll use u'r tips to trying to get it to work propely.
  • 04-28-2009 3:22 PM In reply to
    Also make sure that you use a full SCART cable.
    Cheers,
    Frank
