Hi guys,
Just became a member, so I say hello to everyone and hope to enjoy it here and also learn some from the gurus...
The whole idea right now is to find information about a Reel to Reel tape recorder I inherited from my father. It is from the 1960's and has only been used occasionally for a few years and then stored in a cardboard box till the present.
I also recovered a docen or so tapes that I want to save in CD's, and here is where I have a problem.
I connected the tape to mains, switched it on and it runs just fine; PLAY, FAST FWD, FAST REVERSE, all OK. Problem is that I cannot get any sound out of it; tried speakers 6 Ohm, also headphones, but I only get a grey sound, you know, just "SHHHHHHHHHHH......"
I'm not an electronic specialist of any kind, but quite a good handiman, so as long as it is a tester, soldering or any mechanical issue, I can deal with, no problem.
Right now I'm bogged down due to this problem, so I would very much appreciate it if someone could give me some hints on how to proceed; I'm in the process of cleaning the deck from head to toes. I've stripped it down to the frame and I'm cleaning the contacts on all cards. The old type contacts are filthy (not that I think that it's the solution to my problem, but I might as well remove that possibility).
Waiting for your comments,
Best regards,
Spanish Flyer
