Latest post 04-14-2009 5:27 PM by mr_anders_son. 2 replies.
Page 1 of 1 (3 items)
  • 04-14-2009 12:18 PM
    BV9 with HDTV
    Hi all
    What hdtv stb-s boxes does b&o support? I now use a sagem box (must with canal digital in scandinavia) and my dealer said that no HD boxes are supperted, really?
    Huge dissapointment that built in stb-s module is not hdtv ready.
    Help anyone?
  • 04-14-2009 4:45 PM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Re: BV9 with HDTV
    Hi
    I have a Clarke Tech HD 5000-C which I control directly with the Beo5, thanks to Keith, who made an xml file with all functions. It is not supported by any PUC, but you can download the xml file and program the Beo5.
    It'is not a big help, because you need the Beo5, but I am very happy with it.
    Quim
  • 04-14-2009 5:27 PM In reply to
    Re: BV9 with HDTV
    Sagem is in the list, no problem for your dealer to fix this
