Latest post 04-12-2009 7:41 AM by Luke . 1 replies.
Page 1 of 1 (2 items)
  • 04-12-2009 6:20 AM
    Advice
    Hi all, I have a pleasant problem and need some advice since I can't make up my mind. I have recently sold my 7-40 MKIII and have two options as I see it :
    - Buy the new 7-40 MKIV now and then switch to the new 7-55 when it is launched.
    - Buy the 4-65 Plasma
    What would you guys choose ??
    Here is some of my questions/wonderings :
    - I am a bit afraid that plasma is being replaced by LCD, LED etc. Noticed for example that Pioneer will stop making plasmas at the end of the year. What do you think ?
    - Have anyone seen the 4-65 ? How is the picture compared to the 7-40 MKIII ?
    - The new 7-55 will be LED. What do you think about LED ? Has anyone seen a LED-screen ? How is LED compared to plasma or LCD ?
    - Is it anything else regarding these two models that I should think about ?
    - What kind of plasma screen exactly is it in the 4-65 ? Noticed that the contrast ratio according to B&O is only 3000:1, but I heard from a dealer that B&O doesn't measure contrast the same way as other brands. Is this correct ?
    Many questions and I am very thankful for all comments and opinions.
    Best regards
    Halid
  • 04-12-2009 7:41 AM In reply to
    • Luke
    • Top 200 Contributor
    • Joined on 02-03-2009
    • Switzerland
    • Posts 286
    Re: Advice
    If I could afford it right now I would take the 4-65 with a Beolab 10.
    Isn't plasma faster than LCD anyway ?
    If you are concerned you could always wait for the BV-10. That would be something interesting.
