Not 100% sure about which model numbers apply to 1/2 way versions
but from my experience i would say that the majority are 2-way versions.
Pretty much all had the 2-way hardware, but some of these had 1-way software
(which de-activates the infrared transmitters)
So even if you have a 1-way version, it would be possible to "upgrade" it to a 2-way version
by changing the software to a version higher than 2.0
Some time ago, i re-built a Beomaster 3500 (which is almost identical to Beomaster 4500,
but has grey finish of panel and is 1-way)
and the 3500 did not have the 2-way hardware (no infrared transmitters)
I took the infrared transmitters of a broken 4500 and placed it underneath the glass panel.
After i replaced the 3500 software with a 4500 version, it became a 2-way version
The image (the small one, bottom of page) shows the infrared transmitters underneath the glass panel,
you could check whether your 4500 has the 2-way hardware, if the small square has
the infrared transmitters right above the "SOUND" button, it has the hardware.
You could then place new software to make it 2-way, which gives the 4500 additional functionality
like timer programming for recording / play / stand.by and lights (!)
Note that you would need a 2-way remote (Beolink 5000 / 7000) to be able to use the additional features.
The large image shows the 2-way feedback that the Beolink 5000 (transparent !) display shows when recording.
