Hi all, Im becoming increasingly frustrated with my BV7 since we bought it a couple of years ago. With it being one of the early models its compatibility with HD is very limited. I installed a HD box early this year and ended up with the a HDMi converter to DVi and then audio via normal analogue ports. Since Sky updated the menu system the other week, I keep getting an annoying message up when I select any channel saying "this display does not support HDCP" also the point where I cant actually watch any Box Office Films.
I actually spoke to the tech desk at Sky and to my suprise the chap I spoke to was very helpful and knowledgeable on B&O issues. He advised me to bin the HDMi to Dvi adaptor (which is made by Pure) and buy a Component Cable, as my box is a Thomson HD box which supports Component. The message he said was possibly coming from interference with the HDMi DVi converter.
But isnt component analogue? surely the picture quality wouldnt be as good as HDMi to DVi?
Are there any software updates that might cure this problem before I go and buy a component cable? and if there are updates is it going to cost me another fortune for B&O to install the updates?
Thanks Regards
Dan
