Latest post 04-05-2009 4:32 AM by archie. 6 replies.
Page 1 of 1 (7 items)
  • 03-30-2009 4:15 PM
    • archie
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Paris
    • Posts 497
    auto start of my beosystem 2500
    hello
    the tape of my beosystem 2500 play each monday at 21h05, i push the "clear' button but each monday it's the same thing, how to reset the programation ?
    thank you
    DU BEAU, DU BON, DU BO.
  • 03-31-2009 5:50 AM In reply to
    • Emil
    • Top 500 Contributor
    • Joined on 05-18-2007
    • Stockholm, Sweden
    • Posts 98
    Re: auto start of my beosystem 2500
    As far as I know it is only possible to reset the timer play function with a two way remote, i.e. Beolink 5000 or Beolink 7000. The only thing you can choose without the remote is whether the sound should be on or not (cannot rememember which button to press but I guess you have managed to do this already?).
    Perhaps there is some kind of mastercode to reset the complete system but I guess that's a question for your dealer or local service technician then.
    Wish you luck!
    Inflagrante
  • 03-31-2009 7:23 AM In reply to
    If you download the service manual it may have the service code to re-set everything.
    Regards Graham
  • 03-31-2009 9:49 AM In reply to
    • archie
    • Paris
    • Posts 497
    Yes but it's necessary to take off the rear panel and put something in short circuit Confused for acces to test mode
    I'm not electrician Smile
  • 04-03-2009 6:34 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Archie. See if you can find somebody who will lend a Beolink 7000 to you. You only need it for a few minutes!
    Andy T.
    Poor me, never win owt!
  • 04-03-2009 7:24 PM In reply to
    • frog
    • Joined on 04-19-2007
    • Posts 191
    A 5000 would do the job too - looks like the timer is switched on...
  • 04-05-2009 4:32 AM In reply to
    • archie
    • Paris
    • Posts 497
    The price for the screen is 250 euros [:'(]
    Not like the beo4, the screen is connected to the mainboard on the BL5000.
    I've found on the french forum someone who can help me.
    Thank you.
