Can somebody explain how BeoVision 7 32'' with HDTV module (one DVI input) can be connected to a HDTV source via Motorola 1920 set top box and how in the connections menu of BV7 set tob box must be slected to be able to control it with Beo4
Tahnk u in advance!
First; you have to find out if you BV7 is in fact a HD version..
One DVI input doesnt make it so.
In the connections menu; can you choose between YPbPR and DVI? If you can the TV is in fact HD.
BMGHB
BeoVision10-46MKII,BL3,BL2,BS8,Beo5
Yes I can choose between YPbPR an DVI, so what are the next steps?
