Latest post 03-01-2009 5:25 PM by Eugene. 2 replies.
Page 1 of 1 (3 items)
  • 03-01-2009 3:59 PM
    Speaker Impedance from Beomaster 2400
    After reading the rave reviews over the past several months from you seasoned Beoworlders I had no choice but to drink the Kool-Aid and go out and buy one of those things.
    My question revolves around speaker impedances
    I have 8 Ohm RL 60's. The specs state speaker impedence at 4-8 ohm.
    However I notice most of you fans of the 2400 typically prefer the Uniphase series speaker for hookup.
    My question is will Redlines at 8 ohm cause damage over time to the amp or create a lot of distortion? I suppose it at the very least will result in a little less power coming out say 30 down to 20 watts or something like that.
  • 03-01-2009 5:17 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Speaker Impedance from Beomaster 2400
    The RL60 will be fine for the Beomaster 2400 and certainly won't destroy anything.
    The lower speaker impedance, the greater risk of damage.
  • 03-01-2009 5:25 PM In reply to
    Thanks Martin, that is pretty much how I thought it was, but I thought  I would ask anyways.
    When my next set of Red Lines arrives I can set about to replace the old busted ABR's in my current set with passive radiators.
    I am looking forward to running the 2400 next to the 3000 and see for myself.
