Latest post 03-02-2009 2:40 PM by gtsouk1. 10 replies.
Page 1 of 1 (11 items)
  • 02-27-2009 11:59 PM
    Beocom 1
    Can someone tell me how I can reset a Beocom 1 handset that has another base registered. I bought it used as an additional phone. thank you
    Filed under:
  • 03-01-2009 12:46 AM In reply to
    Re: Beocom 1
    Can you tell what the B&O model number on the BeoLine base is?  Should be a seven-digit number on the manufacturing label of the base, either on its back or bottom.  I take it you have a BeoLine base that has two Line-In sockets, as the BeoCom is two-line capable?    Thank you.
    To reset your handset: MENU > HANDSET/BASE > REMOVE BASE.  Later you should SELECT or REGISTER BASE.
  • 03-01-2009 1:54 AM In reply to
    Re: Beocom 1
    when i try to remove the handset...it says "failed"
  • 03-01-2009 2:02 AM In reply to
    Re: Beocom 1
    So... any luck with the Beoline model number & confirmation you have a two-line Beoline? Wink
  • 03-01-2009 2:47 AM In reply to
    Re: Beocom 1
    it is a beoline 2 line unit TO84149..the O could be zero....thanks for helping
  • 03-01-2009 1:46 PM In reply to
    Re: Beocom 1
    OK, looks like you do have the right 2-line base and I assume your new handset is also a Becom 1 with LINE 1 and LINE 2 as the two top leftmost buttons.  Did you make sure and unplug the BeoLine , wait 2 seconds, and plug it again?  The BeoLine should flash red for a couple of minutes, signaling open to registration.  Try two things:
    1. Technically, you should be able to REGISTER BASE even without first removing the new handset's previous base (Beocom 6000, for instance, can register to more than 1 base).
    2. Did you try AUTO REGISTER?
    Good luck,
  • 03-01-2009 3:29 PM In reply to
    Re: Beocom 1
    You are correct the handset is a two line unit. I tried the process from the manual, both registering from the handset and the 2 second unplugging. I have also unpugged the battery for one hour and retried....now what is the AUTO REGISTER? By the way I doubt that the Beocom 1 is the same as the 6000 when it comes to registering two bases.....is a trip to the dealer the only thing left?
    Filed under:
  • 03-02-2009 7:50 AM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Re: Beocom 1
    What happens if (while the red light on the BeoLine is blinking) you just try 'Register to Base' on the handset?
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 03-02-2009 11:48 AM In reply to
    Re: Beocom 1
    it says "registration failed"
  • 03-02-2009 1:43 PM In reply to
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    Re: Beocom 1
    Try resetting the handset to factory defaults:
    press 9#9#9*HOLD
    turn wheel till it says ‘reset handset’
    press ok and turn wheel to ‘yes’ press ok
    it will reset, power down, then power up again.
    This clears out everything and allows you to register it to a different base.
  • 03-02-2009 2:40 PM In reply to
    Re: Beocom 1
    thank you, it worked
