Latest post 06-04-2007 1:29 AM by Dave. 30 replies.
Page 2 of 2 (31 items) < Previous 1 2
  • 06-02-2007 3:08 PM In reply to
    • SWISS_2
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    Re: Which one should I buy?
    Tom makes a good point about speaker placement, and where the listener is sitting or standing with regards to the BL 4000 (and any speaker for that matter). But your post idea and subsequent comments got me thinking that little comparison might be interesting. This was strictly subjective perception, and non-scientific.
    I took out a CD of Von Karajan's Ring Highlights and listened to my BL 4000's. They sit on a teak cabinet, on the B & O black plastic stands (options) which are canted back about 20 degrees. More or less they are at ear level when I'm sitting, facing both about 3 metres away. Floor is carpeted, walls wood panel in a good sized Living Room.
    Sound is very good, for what I originally thought years ago to be a bookshelf speaker.
    Knowing a friend with a pair of BL 4000 in the corners of his Den ceiling, I mentioned your post, and we sat down to listen to the same CD. Smaller room size. Normal ceiling height, non-carpeted floor. Also a good excuse to open a good South African wine I've been saving.
    Major difference noted: Same superb clean sound, but the CD tracks on his speakers seemed farther away, as they obviously were, and Bass and Treble less distinct. Volume was noted at twice the level. The wine however was really excellent.
    In turn,  my friend and his wife just left repeating the same test at our place, quite impressed. They had not seen the Beoport in action, but that is another issue.( No wine this time: Just coffee )
    The end result is there is considerable difference in speaker sound with placement and acoustic features encountered in two houses, using the same music source and speaker model. In hindsight, again subjectively,  I don't think that I would place mine so high where I sit or watch TV, or against the ceiling.
    I hope this is helpful.
  • 06-03-2007 5:29 AM In reply to
    • Tom
    • Top 25 Contributor
    • Luxembourg
    • Posts 3,175
    good test, swiss2. I remember a very interesting thread in the old forum about toeing in speakers, which concerned only column speakers, and I particularly remember a post by soundproof. I think he mentioned that even by toeing in speakers by some degrees, the result optained could show up some important differences.
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 06-03-2007 7:18 AM In reply to
    • Beo
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Posts 108
    so what do u think the best placement for beolab 4000??
    also, may i ask for beosound 1, is there any tips of good placement?
  • 06-03-2007 1:05 PM In reply to
    • Tom
    • Luxembourg
    • Posts 3,175
    the best placement for any non-ALT speaker is at earhight IMO. I think there are floorstands available for BL4000
  • 06-03-2007 2:27 PM In reply to
    • SWISS_2
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    Beo;
    Two different components. One quite mobile, one more stationary. Both very enjoyable.
    The Beosound 1 is a single unit of 5 speakers, and can be moved around relatively easy. Left, Right, angled, 3 metres over, outside, etc. There are optional wall mounts, a metal stand on a single leg, and a swivel-mounted metal cabinet, open at either side for CDs.
    I can place my BS1 next to a TV, and then below the TV,  and there is different sound quality. You can unplug it and take it in the next room, terrace, garden, or to a neighbor's house. Very good sound ( FM Radio, CD, MP3, TV )  all from one unit.
    Using the AUX cable attachment at the bottom of the BS1, it will accept an MP3 player, or the stereo sound from a TV or SAT box,  as a quick Home Theatre unit. . The BS1 is slightly angled, so the sound is best at ear level as Tom mentioned, or angled to be facing up towards the listener. I can place mine out on a table, and then against a solid wall, and there is a difference in the sound of the music. It's fun to play around with this way, as I'm sure it was designed to be.
    The BL 4000 are single speakers only, well amplified, and not designed to be moved around in the manner the BS1 is. The speakers come with wall mounts in the box, and as mentioned previously there are metals stands (similar to the BS1 stand ), and small plastic table stands as options. Better sound quality I think.
    When I bought mine,  I tried all the options at home first before deciding. This is one benefit of having a good relationship with a B&O store and staff. The metal stands looked good, but didn't work for me: Interested guests, kids, etc. led to the possibility of one or both being knocked over. The wall mounts did not stop the ingenuity of the kids getting up to them, using a chair or climbing up the Plasma. When you place them too high up the wall, you lose the sound quality ( at ear level ) Tom has mentioned.  It depends on your household.
    I chose to place each speaker on a solid surface, each on either side of a Plasma. About a month later, I went back for the small plastic stands, as the sound angle seems to me to be slightly enhanced this way in the living room. They remain placed this way.
    So, as an possible action plan, I would suggest that you consider starting out with a BS 1. Many of us did. The unit can be moved about, sounds great, and the AUX connection has a many applications today. Then consider adding to your AV system , or collection if you will, and move up the ladder as you like.
    I wouldn't reccommend that you wait for the " Ultimate System " from Struer, as it suggests some finite termination, and really doesn't exist. The designs from Struer will keep coming down the Danish expressway, and will continue to do so, evolving as demand, creativity, and technology allow.
    Like Skiing, if you wait for the " perfect powder " to hit the slopes, another year will go  by.
  • 06-04-2007 1:29 AM In reply to
    • Dave
    • Top 50 Contributor
    • Brisbane, Australia
    • Posts 2,328
    I Listened to the BeoLab 4000's today, and was very very impressed, a very good honest sounding speaker if placed correctly, very versatile, and we have decided to buy them as small speakers for the bedroom. They sounded as good and as large as a pair of floorstanders that we previously considered. They look beautiful, and very stately but at the same time they are stylish.
    I now understand why people have said that they are underrated, and we preferred them over the BeoLab 8000's and 6000's. Can't wait to get them!
