Latest post 02-19-2009 2:57 AM by riis. 4 replies.
Page 1 of 1 (5 items)
  • 02-18-2009 5:23 PM
    • riis
    • Top 500 Contributor
    • Joined on 05-01-2007
    • Denmark
    • Posts 152
    Adding a button to an "old" Beo4
    I've just purchased a Beo4 to replace my Beolink 1000. It's the model without the dvd-button. With the BL 1000 I could switch to AUX on my Beocenter 9000 by pressing [SHIFT] and then [RADIO]. I know I have to press [STAND BY]+[LIST] in order to add a new button, but after doing that I'm lost. Can anybody help me?Confused
    /riis
  • 02-18-2009 5:30 PM In reply to
    Re: Adding a button to an "old" Beo4
    on the screen it will say ADD? Hit go, then use your up and down arrows to scroll through the options. Click go when the option you want is displayed. It should then be added.....
    My B&O: 2009 Catalogue and Pricelist
  • 02-18-2009 6:01 PM In reply to
    • riis
    • Denmark
    • Posts 152
    Maybe my Beo4 is very old because I haven't got the ADD?-option. Instead I have CONFIG? and AUX doesn't seem to be an option.
  • 02-19-2009 1:43 AM In reply to
    When you pressed [STAND BY]+[LIST], you can scroll trough the options by pressing [LIST]. You should see Add? and Remove? and so on. I have also an old Beo4 without the DVD button.
    Piet
  • 02-19-2009 2:57 AM In reply to
    • riis
    • Denmark
    • Posts 152
    Thanks Piet, you are quit right. I made the mistake of pressing GO after CONFIG? appeared in the display. That's why I couldn't find ADD? So now everything works just fine.Big Smile
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
