Latest post 05-26-2007 1:11 PM by brunetto77. 4 replies.
Page 1 of 1 (5 items)
  • 05-26-2007 11:31 AM
    profile settings
    How do you add a permanent picture to your profile?
    Bruno
  • 05-26-2007 12:05 PM In reply to
    Re: profile settings
    Click on your name which you will see at the top right of the screen. Once the new window opens, click on the tab called Avatar and then download a picture from your computer.
  • 05-26-2007 12:55 PM In reply to
    Thanks Peter,
    I should have known Confused
    B
  • 05-26-2007 1:03 PM In reply to
    Is the phone working?
  • 05-26-2007 1:11 PM In reply to
    Yes Peter,
    both phones are now working. I've put one in my bedroom and the other in the living room. From what I've understood if you select base 1 on the menu, when you press the round button and scroll the wheel you only see the entries number. However if you select auto select for the base you can also see the message: Open base 1.
    No idea about the difference but either way they work well with the updated phonebook.
    Thanks again
    B
