Hi guys,
I read on beocentral that passive speakers can be used with the Beocenter 2500 when connected to an MCL 2P amp. Can passive speakers also be used on the Ouverture/4000 with the MCL 2P?
Regards,
Aaron
Certainly can.
You could also use ML/MCL converter or BeolinkPassive or MCL2P with ANY of the upright music centres!
Simply connect the two devices with a fully wired (Mk2) powerlink cable, connect you passive speakers and away you go.
Regards Graham
Great!
Thanks for the reply, Graham.
