Latest post 02-11-2009 12:52 PM by djdanielb. 7 replies.
Page 1 of 1 (8 items)
  • 02-10-2009 4:30 PM
    BeoCom 6000 change firmware
    Hello !
    Wonderfoul forum, nice people. Nice to meet you.
    I'm writing about a Beocom6000 (cordless telephone) with Germany firmware . It doesn't works in Italy (the country where I live)
    Can I change the firmware ?
    What kind of interface I need ?
    Where can I find the firmware ?
    Thank you so much
    Djdanielb
  • 02-10-2009 4:39 PM In reply to
    Re: BeoCom 6000 change firmware
    A very warm welcome to Beoworld.
    The firmware in the Beocom 6000 and its base can be uploaded from a PC using a special service jig and B&O software in a PC.
    Not all B&O dealers have the facility themselves and would often send it to a B&O service centre for software upgrades etc.
    Below is a picture of a Beocom 6000 handset service jig
    Regards Keith....
  • 02-11-2009 10:21 AM In reply to
    Thank you so much ! can i buil this interface ? is a com adptor ? have you got the firmware ?
    Best regards Daniele
  • 02-11-2009 10:47 AM In reply to
    Have you got a pinout of this interface ? I could build it by myself and update with your firmware.
    I hope that you resolv my problems.
  • 02-11-2009 12:07 PM In reply to
    Daniels,
    It's not that simple. It does use a standard RS232 interface from the PC, but you will need the firmware and the Beocom software service Tool, as you have neither, it means you will need to take it to your B&O dealer for update.
    Regards Keith....
  • 02-11-2009 12:19 PM In reply to
    Thanks for you fast answer !
    Build an RS 232 interface is not a problem for me. I could use a MAX323 chip ora a simple BC transistor. I'm working in a mobile phone service centre and I update mobile phone every day.
    Build the cable is the easiest thing
    I suppose that the 2 pins are TX and RX or TX and ground.
    the problem is the firmware and the flash program
  • 02-11-2009 12:33 PM In reply to
    No, you misunderstand, the jig plugs directly into the PC comms port and the RS232 signal is already generated within the Beocom 6000.
    If you take the battery compartment off  the phone under the led you will see two small holes with gold pads which are the transmit and receive signals as below:-
    Regards Keith....
  • 02-11-2009 12:52 PM In reply to
    Wonderfoul ! we only need the firmware and the flasher
    The pinout should be simple
    COM PORT PINOUT
    Have you got this firmware or do you know where I can find it ?
