A dear friend of mine came to me with his Beocenter 9000 and asked me if there where anything to do to make it work again. I thought I could have a look at it and after reading about it in this forum I knew that the CD player could be a problem.
At first as a old member I looked for service manuals. I found nothing for the BC9000.
After cleaning the laser/cd player I tried to play a cd and it seemed to play as it should according to the display, so this is ok but
1 Connected speakers (also headphone), but no sound in all outputs. Tried radio-no sound, connected on the AUX no sound,
2 The Radio when automatic search for radio-signal it goes straight to 108 . Manual search ok - but no sound in speakers
3 No function in the tape recorder - but I assume this is the same as in other tape recorders (belt or???)
4 Sliding doors to the tape recorder/cd player do not work. manually they work.
Otherwise the BC is beautiful, light in all display etc.
Do anybody have some views on this and I will be grateful?
