has there ever been a single one of this style of beograms where the tape has not failed?
you might try a high quality double-sided "servo" style tape... 3m makes some good products. i would suggest playing around w/ perhaps some card stock stacked like shims to get the thickness right, 'cuz once that stuff is stuck down -good luck!
hobby shops with a r/c section usually stock some...
