Latest post 05-29-2007 3:13 PM by phillipn. 3 replies.
Page 1 of 1 (4 items)
  • 05-25-2007 6:58 PM
    Beomaster 1001 speaker plugs
    I have recently bought a Beomaster 1001 tuner-amp which worked well expect for a wobbly speaker plug on the righthand channel.
    On investigating, I found that the socket had loosened from the circuit board.  Attempts to resolder the connection have not been entirely satisfactory as the track on the board is damaged and I cannot easily see where to connect a suitable bridge.  I understand that a circuit diagram was probably provided with the machine when new but that was long, long ago.  Can anyone help with a copy, or comments, please.
    Yours
    Phillip Newmarch
    Filed under:
  • 05-26-2007 3:28 AM In reply to
    Re: Beomaster 1001 speaker plugs
    I actually have the service manual for this which I will scan today and put on site. You will need to upgrade to silver or gold to get to it but as that could result in you winning a new system if you upgrade to gold, it could be the best decision you have ever made! Laughing
    There was probably a circuit diagram with the 1001 - usually in a small brown envelope - but the service manual is much better!
  • 05-26-2007 6:16 AM In reply to
    Manual now on - I have scanned the diagrams in colour as it makes them stand out more.
  • 05-29-2007 3:13 PM In reply to
    Thanks - that was very quick.  I havent had a look yet, but will do so now.
    yours
    phillip newmarch
