Of all my remotes, my favourite is the older Beo4 with the AV button. However, it seems to have a bug with the STAND command (I use it quite often, as I can see the TV from the kitchen if I rotate it). Sometimes - maybe once every second day - the STAND mode forgets to timeout from the display (usually it timeouts after 30 seconds or so since you last operate the stand). Then, when I try to rotate the stand "blind" I click once on LIST and then press a number, but as the remote hadn't returned to TV mode, I end up changing the channels randomly or something else....
Has anybody else noted this problem, and is there anything that can be done about it?
