Latest post 02-01-2009 6:36 AM by BeoMeowth. 5 replies.
Page 1 of 1 (6 items)
  • 01-31-2009 1:18 AM
    Beosound 2300 glass door won't work, cable sticking out...
    Hello, new to the forum.  I just purchased a beolab 2300 off ebay, the seller shipped the item with the glass door installed on the unit.  I opened the package and noticed the left door was sagging a bit, after powering it up, I can hear the motor trying to open the glass door and was struggling; so I gave it a gentle push to get the door opened.  Now the door won't close and I have a cotton cable sticking out from the top of the unit.
    Does anyone know how to repair this?  I'm quit handy when it comes to electronic equipments, should I try to tackle this issue myself or would I be opening a whole world of hurt?  The wire, seems to me, should be looped around some pully in the machine, however has come lose from it.  Anyone know how to open one of these machines up?
    thanks!
  • 01-31-2009 2:45 AM In reply to
    Re: Beosound 2300 glass door won't work, cable sticking out...
    so I just opened it up, and it looks like one end of the cable is lose.  But the cabling is mind boggling, anyone has a diagram or know how the cabling works?
  • 01-31-2009 7:28 AM In reply to
    alright, after 5 hrs of hell on earth i got the glass sliding doors to work.  However, now it doesn't listen to my motion.  The cd door will only open if one of the button on the inside is pressed.
    I'm assuming the module that controls the motor is fried?  Since that's the only piece I touched.  Anyone know where i can get anothe module?
  • 01-31-2009 11:04 AM In reply to
    Hi There,
    A warm welcome to Beoworld....
    Do you mean the CD clamper (the thing that opens to put the CD under?). If so this only opens when you press 'load' on the control panel inside the glass doors, as I assume you are referring to.
    The glass doors are the only thing that opens based on movement in front of the unit.
    Trust that helps.
    Laurence.
  • 01-31-2009 2:40 PM In reply to
    ah, it was getting too late last night.  I meant the glass doors do not respond to my motion.  only if i push them apart a little bit where I can press a button then the doors slide open by themselves and it will close a moment later.  However it does not open to my motion.
  • 02-01-2009 6:36 AM In reply to
    alright, it seems like it fixed itself...  The cabling was pure hell though, i'm just glad i finished it.  Took me like 4 hrs just to understand how the cables were working, and anohter 2-3 hrs just to put it together
