Latest post 01-28-2009 9:56 AM by havenboy. 0 replies.
Page 1 of 1 (1 items)
  • 01-28-2009 9:56 AM
    Beocenter 7000 - early lifting stylus problem
    HI
    I have put a message on here previosuly, but despite kind suggestions from members at solving the problem I am none the wiser
    I have a Beocenter 7000,which judges the size of the LP correctly , but usually only makes it between 50% and 60% of the way through the LP before lifting the stylus arm and returning to its original position automatically.
    If I move the stylus by hand to start at a particular position it will play until the end but I have never yet got it to do one complete side of an LP.
    I considered that it might be the weight sensor but have tried running it with 2p's on top to weigh it down and the same problem occurs.
    I have tried, tunring off and on again - I have tried resetting all of the clocks etc so that it cannot remember any settings that might be affecting this.
    Does anyone have any suggestions as it is a lovely unit, usually the lids go on these but it is in really good condition and I would love to get it going again.
    Sean,
