Latest post 01-28-2009 1:47 PM by tomsloat. 2 replies.
Page 1 of 1 (3 items)
  • 01-23-2009 12:08 PM
    speaker selection 4 or 8 ohms (opinions appricated)
    hi can any one advise i've got a beomaster 2200 i'm currently running jbl control 1's @8ohms on this  but it seems to suport 4 ohm speakers. is there any benifit in replacing these with a 4 ohm speaker?. any speaker suggestions gratefully received. thanks in advance ...
    many thanks
    tom
  • 01-28-2009 7:36 AM In reply to
    • Xseries
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Hampshire
    • Posts 433
    Re: speaker selection 4 or 8 ohms (opinions appreciated)
    The early Beomasters (and the odd early Beolab) were rated for output into 4 ohms as that gave them a higher power output when comparing performance figures with competitors.  Over time this became less important and most amplifier outputs and B&O speakers were changed to "8 ohms".  The latter is more important when running mutiple sepakers for example on an early MCL 82 type link but otherwise there is not much difference - apart from the aforementioned power - ie with 8 ohms you will not get quite so much overall volume as you could with a lower impedance.
    In other words it should not make too much difference - but if you plan to run multiple passive speakers start with 8 ohms!
    Brian
  • 01-28-2009 1:47 PM In reply to
    thanks brian
