Hi All
Ive had a Beolink PC2 box sitting around doing nothing for over a year along with a lab 3500 sat on the wall not being used, so this week decided to hook then both up in my home office ....but having a few probs.
1. Ive installed Beoport software which all seems to work fine coming through my PC speakers (Harman Kardon). (apart from a hissing noise every now and then which is strange as i do not get this if playing music from media player or itunes .... any ideas here ???)
2. I installed the beolink PC2 to the computer (USB cable) and ran cables to the beolab 3500 .... I have run both a masterlink cable straight from the PC2 box along with a Powerlink Mk 2 cable.
Problems.
1st I get NO sound from my Beolab 3500 ??
2nd Should this configuration i.e a beolink PC2 connected directly to the Beolab 3500 (with masterlink and powerlink) enable the display (time) on my 3500 ?? As currently I get nothing, in the manual it says this only works on certain configs ??
Any help would be great.
Scott
