Latest post 02-04-2009 7:38 AM by zazouzt. 10 replies.
Page 1 of 1 (11 items)
  • 01-18-2009 6:42 AM
    • zazouzt
    • Top 500 Contributor
    • Joined on 04-17-2007
    • near Strasbourg/France
    • Posts 123
    Wrong Riaa Diagram in Service Manual
    Hi all,
    I just noticed that the Riaa diagram in the "BG3000-700_service-eng.pdf" is not the right diagram.
    In my Beogram4500 (type 5951) , i have a  Riaa Card  with the reference 8005250C and in the Service manual, its a 8005269
    As i have problems with my beogram actually, i need to know what the difference is.
    If someone could help with the right diagram, or......
    Thanks a lot
    Théo
  • 01-24-2009 2:54 PM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Re: Wrong Riaa Diagram in Service Manual
    Hi Theo
    My BG4500 (Type 5953) has RIAA # 8005250B - I used the service manual to check my unit, and didn't come across any inconsistencies.
    Perhaps I didn't have the problem you had.
    Would you like to tell us what kind of problems you've got?
    Menahem Yachad
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 01-26-2009 9:36 AM In reply to
    • zazouzt
    • Posts 123
    Hi Menahem,
    i'm looking for some advice.
    For instance, wich wire from the Din plug goes to wich soldering place on the riaa pream.
     there are 6 soldering places and i don't know the real place for each wire.
    Thanks for your answer
    Théo
  • 01-26-2009 9:57 AM In reply to
    • yachadm
    • Jerusalem, Israel
    • Posts 687
    Hi Theo,
    I've sent you pictures of my BG4500 with the wiring positions.
    Let me know if that helps you solve the problem.
    Menahem
  • 01-27-2009 8:25 AM In reply to
    • zazouzt
    • Posts 123
    Hi Menahem,
    Yes it helps...
    But as i said in another Post, my cable doesn't have the same colors.
    So the "must" would be, ( I do not dare to ask for it),  to check your Din plug, so we can be sure.
    Théo
  • 01-27-2009 11:35 AM In reply to
    • yachadm
    • Jerusalem, Israel
    • Posts 687
    Here is a home-made wiring diagram - using my board and my wiring colours ... now with an ohmmeter you can trace the correct wire.
    The 3 black wires are wired together = all to ground.
    The Yellow is the data-link
    The Red is Right Channel
    The White is Left Channel
    Doesn't matter what colors you have - the same solder points on the PCB go to the same pins on the DIN 7 connector.
    Menahem
  • 02-02-2009 8:29 AM In reply to
    • zazouzt
    • Posts 123
    Hi Menahem,
    This time it works !
    It remains a little problem : the left channel is not so loud as the right channel
    I controlled all the solderings and all is ok. i controlled also the  Pickup arm height and parallelism, and
    this was also good.
    But it doens't  annoy me too much.
    It's great to sit and hear my favorite LP discs
    Many thanks for your help.
    Best Regards
    Théo
  • 02-02-2009 8:39 AM In reply to
    • yachadm
    • Jerusalem, Israel
    • Posts 687
    You may need a new cartridge to correct the sound problem.
    Try Sound-smith.com  in the USA - an SMMC4 would be fine.
    Buying a second-hand cartridge is very risky.
    Menahem
  • 02-03-2009 9:35 AM In reply to
    • zazouzt
    • Posts 123
    The cartridge (MMC2)  seems correct, and i have also a MMC4, and it's the same with both.
    Théo
  • 02-03-2009 12:07 PM In reply to
    • yachadm
    • Jerusalem, Israel
    • Posts 687
    If both cartridges are giving you low sound on the same channel, the first place I'd check would be the contacts of the mute switch for oxidization.
    A good quality contact cleaner, would do the job.
    If you have an Oscilloscope, check the signal paths of both channels to find where the sound output level drops.
    Menahem
  • 02-04-2009 7:38 AM In reply to
    • zazouzt
    • Posts 123
    Thanks, i'll check  the contacts of the mute switch asn soon as possible.
    and if it's not this i must wait since i find an oscilloscope.
