Latest post 01-12-2009 3:16 PM by TWG. 6 replies.
Page 1 of 1 (7 items)
  • 01-11-2009 4:55 PM
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    Does Beosound 5 has a standby indicator (e.g. red LED)?
    Good evening,
    I have a real dumb question but I couldn't find any answer:
    Does the Beosound 5 controller has s.th. like a standby indicator, e.g. a red Led like  other Musicsystems?
  • 01-11-2009 5:39 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Does Beosound 5 has a standby indicator (e.g. red LED)?
    Yes.
    Stefan
  • 01-11-2009 8:19 PM In reply to
    At the rear of the screen panel, top right hand side, approx 1cm in and down, there is a tiny "hair-pin" trigger which switches the unit to standby.
    The Red LED is in the same position of the screen side.
    10%
  • 01-11-2009 11:06 PM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    Thank you :-)
    so it's not clearly visible on the front glass? I didn't even notice the standby switch on a display unit in the store!?
  • 01-12-2009 3:26 AM In reply to
    • stefan
    • Posts 1,733
    It is clearly visible. Similar to a BV7 screen with red standby led. The switch is a very small button at the rear as 10% said.
    Stefan
  • 01-12-2009 4:21 AM In reply to
    The Beosound controls are shown below
    Regards Keith....
  • 01-12-2009 3:16 PM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    thank you guys :-)
