Good morning,
will it be possible to change the harddrive(s) inside the Beomaster 5 to a solid state drive with the same capacity?This would be great as the unit would not make any noises (except if there's a fan for cooling inside) and - in theory - there's no component that can "crash".Is windows on the harddrive or do they use a flashrom (e.g.) for the embedded system?Thanks
In theory you could, but at present, SS drives seem to be just as prone to failure as HD drives, are incredibly expensive and also only offer small capacities at present.
Weekly top artists:
