try to turn it off and on again (hold the center button till it turns off).
If the configuration is faulty, try to enter the configuration menu: Press and hold the red dot button, than press the center button while still holding the red dot button.
Now choose "default" configuration of the beo 5 and it should work.
Hope this helps. If not: contact your dealer!
