Latest post 05-04-2009 7:21 AM by BenSA. 14 replies.
Page 1 of 1 (15 items)
  • 01-02-2009 3:40 PM
    • Pault1965
    • Not Ranked
    • Joined on 04-22-2008
    • Rogiet, South Wales
    • Posts 36
    RL 140 Foam Rot
    Without wishing to stir up a hornets nest, I am looking for some sound advice!
    My RL 140's are both suffering with foam rot, the drivers are ITT brand. Should I attempt repair
    (never done this beforeHmm) or just get new drivers?
    Thanks in advance for your help.
    Cheers Beer
    Paul
  • 01-02-2009 4:38 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: RL 140 Foam Rot
    The original drivers are 6 ohms, practically impossible to replace with anything else.
    Worth repairing the original drivers but tolerances are extremely tight in this type of driver so I wouldn't recommend you try your luck on these if you never did anything like this before.
    Also worth replacing the old and dried out capacitors in the crossovers while in there. A kit is available.
  • 01-03-2009 12:31 PM In reply to
    • Pault1965
    • Not Ranked
    • Posts 36
    Re: RL 140 Foam Rot
    What will changing the capcitors in the crossovers do?
    Paul
  • 01-03-2009 3:48 PM In reply to
    • Dillen
    • Posts 5,008
    Re: RL 140 Foam Rot
    Generally, it will brighten up the sound, bringing it back to where it was originally when the filter capacitors were still fresh. Not all redline speakers capacitors are bad, still many owners become positively surprised after a re-cap.
  • 01-03-2009 4:04 PM In reply to
    • Pault1965
    • Not Ranked
    • Posts 36
    Re: RL 140 Foam Rot
    How much are the kits please?
    Also do you still have 4 drivers?
    Paul
  • 01-04-2009 7:34 AM In reply to
    • Dillen
    • Posts 5,008
    Re: RL 140 Foam Rot
    Paul, you have a PM.
  • 01-07-2009 7:50 AM In reply to
    • Xseries
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Hampshire
    • Posts 433
    Re: RL 140 Foam Rot
    Could you please also send me a PM regarding the capacitors!
    Mange tak
    Brian
  • 01-07-2009 8:16 AM In reply to
    • Dillen
    • Posts 5,008
    Re: RL 140 Foam Rot
    Done !
  • 01-18-2009 12:20 AM In reply to
    Re: RL 140 Foam Rot
    Hi Martin,
    I am also getting a little distortion from one of my redlines. Think the foam must have gone.
     Can you let me know cost of kits..? I will then send in to a high end speaker repair man to complete the repair. They have not been worked on for some time so think the capacitor set would also be a good plan, so please send me the costs on these also.
    Thanks in advance,
    Guy
  • 01-18-2009 4:56 AM In reply to
    • Dillen
    • Posts 5,008
    Re: RL 140 Foam Rot
    Guy,
    Welcome to Beoworld !   Yes -  thumbs up
    I don't sell refoam kits, only the cap kits but
    I'm sure your high-end speaker repair-shop will have all the parts needed, probable even audiophile caps.
  • 01-19-2009 8:56 AM In reply to
    Re: RL 140 Foam Rot
    Thanks for the speedy response Martin. I pulled the back of the defective unit and it is gone. I did find a set of foam repair kits on eBay. Sorted. How much are your cap kits..? Think it is a good time to repair the lot at once.
     Cheers Guy
  • 01-19-2009 9:06 AM In reply to
    • Dillen
    • Posts 5,008
    Re: RL 140 Foam Rot
    Guy, you have a PM !
  • 04-29-2009 1:11 AM In reply to
    Re: RL 140 Foam Rot
    1 is 5 ohm and the other is like 14 ohm. weird but thats what mine read.
  • 04-29-2009 2:12 AM In reply to
    • Dillen
    • Posts 5,008
    Re: RL 140 Foam Rot
    The 5 ohms measured as DC resistance would be about right, the rest is far out. Have you measured in-circuit or out ?
    Also note that speaker impedance (AC resistance) is different from the DC resistance your multimeter will give you (and greatly frequency dependent).
  • 05-04-2009 7:21 AM In reply to
    • BenSA
    • Top 75 Contributor
    • Durban, South Africa
    • Posts 808
    • Gold Member
    Re: RL 140 Foam Rot
    I just the woofers from My RL 140's to be repaired. The place I sent to are known to be very good only thing is they are replacing the surrounds with foam. They say the only replace things to original specifications. They said it would make a slight difference if one were to put rubber surrounds.
    Durban South Africa
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
